Gas filling -up slow and gas spit back= taking a long time to put gas
ski.dive
I need to replace my Bronco's gas tank vent hose.
How did the WASHING MACHINE HOSE that you used to vent the gas tank hold up inside the gas tank?
Did it do OK, or did it MELT with the gasoline?
Is it still holding up?
If not, what other hose size [diameter] can I use as a VENT hose for the filler neck on my BRONCO?
S
ski.dive
What is the diameter of the filler neck vent hose???
This vent hose is INSIDE of the gas filler neck.
I've seen people use a ''Washing Machine flexible Plastic Drain Hose' to replace the BAD vent hose that is inside the filler neck
***I NEED TO KNOW IF ''Washing Machine flexible Plastic Drain Hose' to replace the BAD vent hose that is inside the filler neck is OK to use.
SEE attached PICTURE OF WASHING MACHINE HOSE used as vent hose!!!
I've read that:
Most often the cause of slow fill up or "spit back" of fuel while refueling is a problem with the filler neck vent hose.
This vent hose is usually inside the filler neck and runs down to the fuel tank.
S
ski.dive
What hose size [diameter] can I use as a VENT hose for the filler neck on my BRONCO?
Where can I purchase this vent hose?
No one has this hose, that's why I think people are using a Washing Machine Hose
Yo ski,
Appears it is out of stock from usual sources..
Call our sponsor, Jeff'so Bronco Graveyard..here is the rubber hose...
http://shop.broncograveyard.com/1980-1996-Ford-Bronco-Rear-Tank-Filler-Hose/productinfo/30218/#
Out of stock here
http://www.fillernecksupply.com/1987-1988-1989-1990-1991-1992-1993-1994-1995-1996-ford-bronco-full-size-fuel-filler-neck-e7tz9034m-01/
1987-1996 FORD BRONCO (FULL SIZE) FUEL FILLER NECK E7TZ9034M-01
$74.95
SKU:
FNSF4G
http://www.fillernecksupply.com/1987-1990-1991-1992-1993-1994-1995-1996-bronco-fuel-filler-hose/?gclid=Cj0KEQiAvJS3BRDd44fjndyii6MBEiQAN4EkPUItv89swXtdRaLTsSK4e-phghgstSBkvYrlF9g9kF4aAox48P8HAQ
Rubber Connection Hose that runs from fuel tank to filler neck.
Neck Diameter: 2" Inch
Tank Diameter: 2-1/4" Inch
Length:11-12" Inches
Note: Uses Reducer **** To Achieve 2 inch Id At Neck
http://cdn3.bigcommerce.com/s-m7zic/products/4957/images/5183/1987-1996-Ford-Bronco-_Full-Size_-Rubber-Fuel-Filler-Hose-D225A45L13B05-01_image1__95199.1421835147.340.340.jpg?c=2
Vent & Fill Tube pics in pre 87 & 87 & up; "...Early trucks use a small corrugated plastic vent tube tucked into the top of the steel filler neck , but it often kinks & blocks fuel from entering the tank easily. Later trucks use a heavy plastic filler hose inside the steel vent neck, which allows MUCH easier filling.The necks are interchangeable, so it's a good upgrade for an old truck, especially if filling is becoming a problem. It also allows the use of a more modern gas cap..."
fillerneck93.jpgSource:
http://www.supermotors.net/registry/media/285175
http://www.supermotors.net/vehicles/registry/media/514258
by Steve
CD66
