I have a 1983 bronco with the inline 6 replaced fuel pump the other day and now it won’t start turn key on lights come on but once I turn it to attempt to start the power cuts off any ideas what wire I knocked loose in the process
Appreciate the response did as you said also went as far as replacing the solenoid and no he’ll still not even turning over just cuts the powerHey Ccarder,
Sounds really simple, but check your battery cables. Make sure theres no corrosion between the posts snd the clamps.
If thats good, check where the pos cable connects to the solenoid in the fenderwell.
Good luck
Cheers
Hey there CcarderI don’t know if the headlights cut out I’m kinda in the process of putting it back together so it doesn’t have a grill headlights or anything. I do know the lights on the dash and the radio loses power when I try to start it also.
I didn’t break it down that far. It was running perfectly fine other than the fuel pump leaking replaced the fuel pump then after that, it wouldn’t start. I’m assuming I bumped something over on that side. Only other thing I’ve done is pull the windshield off cause it was cracked.Hey there Ccarder
If its in the process of being assembled, you might not have a body ground connected. (Between the block and body.)
I would follow Tiha's suggestion. Connect a booster cable between the engine ground (pick something not painted, like the alternator housing) and the truck body. (The ground strap usually runs between the back of the intake and the firewall.) See if it will start then.
Good luck
Cheers!
So just finally got around to working on it hooked the headlights up and they stay on when the key turnsBasically what you are looking for is if everything goes dead, then you have a battery, connection, cable issue. That is all having the headlights on would help you determine.
I think most of the other lights are supposed to go out while cranking so they are not a great indicator of a main power failure.
What about the power outlet, where you charge your phone, is it directly wired and on all the time? You can stick something in there and see if it still has power when trying to crank.
Do you have help? Have someone out a test light on the solenoid you replaced while trying to start the engine. See if the power stays on or goes off.
So replaced the solenoid and the cables that come into each side still no luck only other thing to add is I did find out the bronco had a security system in it where do they usually wire them in to power the security systemIf the headlights stay on, that means the battery connection is good.
So now it is either the solenoid on the fender well, the starter itself, or the cable in between the two.
Thought of another thing I removed the hood and it had a body ground that went from hood to fender if that is not connected could that be causing it?Security systems, Yeah that can be a mess.
The easiest place to attach one is right under the steering column. Above the brake pedal. Start looking for electical tape, or signs someone was in there screwing around.
It will all go to a small black box that doesn't look like it belongs. Probably not mounted anywhere. Just laying under the dash somewhere.
Security systems often use a coil **** as well as a starter ****. The starter **** is probably wired into the steering column. The coil side could be out on the wiring to the coil.
Good luck, that sounds like a mess.
