Fuse box diagram for 82 bronco? Need to fix ignition
Dallas82Bronco
Dallas
Just bought an 82 that someone broke off a key in the ignition then tried to rig a push button. Need to start from scratch.
Bet how hard is it to replace steering column in one of these?
Yo Dallas82Bronco,
1982 Ford Truck Bronco
Removal and Installation
Steering Column
Removal
1. Apply parking brake and disconnect battery ground cable.
2. Remove bolt and nut attaching intermediate shaft to steering column.
3. Disconnect shift linkage rod(s) from column.
4. Remove screws from underneath steering wheel, then lift horn switch assembly from steering wheel.
5. Disconnect horn switch wires by pulling spade terminal from blade connectors, then squeeze J-clip ground wire terminal and pull it out of hole in steering wheel.
6. Remove horn switch assembly, then the steering wheel retaining nut.
7. Using suitable puller, remove steering wheel from shaft. When servicing a tilt steering column, the steering wheel must be in the full ``UP'' position when removed.
8. Remove steering column floor opening cover plate screws.
9. Remove shroud by loosening ***** at bottom, selecting position ``1'' on manual 3 speeds and automatics and spreading shroud open, and withdrawing out of instrument panel opening while pulling up and away from column.
10. On vehicles with automatic transmission, remove shift lever cable.
11. Remove instrument panel column opening cover.
12. Remove column support bracket to pedal support bracket attaching bolts.
13. Disconnect turn signal/hazard warning and ignition switch wiring harnesses.
14. Remove column from vehicle, then the column support bracket from column.
Installation
1. Attach steering column support bracket, ensuring that turn signal/hazard warning wiring is on outboard side of column, torquing nuts to 13-38 ft. lbs.
2. Hand start floor opening cover plate clamp bolt and press plate until clamp flats abut stops on column outer tube.
3. Load column into vehicle through opening in floor.
4. Connect turn signal/hazard warning and ignition switch wiring harnesses.
5. Raise column to pedal support bracket and hand start two bolts.
6. Fasten floor opening cover plate to floor, torquing screws to 6-10 ft. lbs.
7. Torque two support bracket bolts to 19-27 ft. lbs. and the cover plate clamp bolt to 8-18 ft. lbs.
8. On vehicles with automatic transmission, install and adjust shift lever cable.
9. Install instrument panel steering column opening cover.
10. Mount shroud by selecting position ``1'' on 3 speed manuals and automatics, spreading shroud around steering column and through opening in instrument panel. Post on interior will index shroud when properly positioned.
11. Torque ***** at bottom of shroud to 10-15 inch lbs.
12. Attach shift linkage rod(s) to column.
13. Connect intermediate shaft to steering column, torquing bolts to 45-59 ft. lbs. on 1980-85 models and 35-50 ft. lbs. on 1986-87 models
14. Position steering wheel into place with retaining nut, then torque nut to 30-40 ft. lbs.
15. Connect spade terminal of horn switch wire to blade connector and press J-clip ground terminal fully into threaded hole.
16. Center horn switch on steering wheel and install attaching screws.
17. Connect battery ground cable.
When the steering column is installed in the vehicle it is not susceptible to damage through ordinary use; however, when it is removed, care must be taken during handling. Such actions as a sharp blow on the end of the steering shaft or shift levers, leaning on the column assembly or dropping of the assembly could loosen or shear the plastic shear joints or rivets used to maintain column rigidity. Hammering, jolting or bumping on the steering shaft and gearshift tube must be avoided during all service operations. If the shear pins are broken, the controlled length of the telescoping design will be altered making these components unfit for further service. When removing the steering wheel, only a steering wheel puller designed for this purpose must be used.
It is important that only the specified screws, bolts and nuts be used during the assembly procedure and torqued to specifications to insure proper breakaway action of the column under impact. Avoid using excessively long bolts or fasteners as they may prevent a portion of the steering column from collapsing. When replacing fasteners, replace with ones of the same part number or equivalent.
EEC III Testing, Pin-Outs, Wiring & Vacuum Diagrams in an 82 by Tommy
DIY EEC III Timing Procedure by Eric, DONOTDELETE @ EEC III - Off-Road Forums & Discussion Groups
1982 Bronco "What's New for 1982" Brochure by Gary
1982 Light Truck Facts Book by Gary
1982 Bronco, F & E Series Accessories Brochure by Gary
1982 Bronco Advertisement "A lion in winter!"
1982 Fastener Pictures & Illustrations by Gary
1980-1986 Bronco/F Series Carburetors, Chokes & EFI by Gary
1980-1986 Bronco/F Series Specifications by Gary @ Axle Ratios - Gary's Garagemahal (the Bullnose bible)
Differences in 1980-1986 Bronco/F Series by Gar
johnnyreb
West Virginia
Bet how hard is it to replace steering column in one of theseWhy don,t you just replace the switch. Alot less work and alot cheaper
johnnyreb
West Virginia
Question is, how hard is it to replace the buggered ignition lock cylinder?
Type in ignition switch replace for 1982-92 Ford truck-youtube and hit enter--and several places show you step buy step--YOUTUBE UNIVERSITY shows you alot
No juice
Washington
It is not hard to replace the steering column, The hardest part is finding a good one that’s not all worn out. I’ve tried to find a good aftermarket but there is none for the 80s bronco. If you do not have a shift on the column then it probably isn’t that big of an issue to find a good one.
johnnyreb
West Virginia
Try COLUMN SERVICE--they have alot of new parts for different makes and years.
Ask at local yards if they cater to local column repairers.
A high cost comnercial column rebuilder is https://www.steeringcolumnservices....-rebuilt-non-tilt-f-series-steering-column.ph
1980-1991
F150, F250, F350 Series Pickup, Bronco
  • Non Tilt
  • Column Shift-Automatic Transmission
  • Column Housing Length - 31"
Our Part # Column F80-91CN
Fits Makes: F Series, Bronco - F150-F350
Fits Years: 1980-1991
$775.00 -- (plus core charge)
  • Turn Lever ($18.00)
  • Shift Lever ($45.00)
  • Available during checkout
The entire column has been disassembled, cleaned and refinished. Each of the parts below have been cleaned, carefuly inspected and replaced (if needed) to ensure a fully functional, rebuilt condition. All you need to do is install the column in your truck, put the steering wheel on and enjoy it. During the rebuild process we inspect, replace and/or refurbish the following parts:
  • Upper Bearing
  • Lower Bearing
  • Ignition Lock Cylinder w/ 2 Keys (new)
  • Turn Signal Switch (new)
  • Ignition Actuator
  • Ignition Rack Gear
  • Igntion Switch (New)
Note: There is a $120.00 core charge added during your checkout process. This fee will be credited back to you upon return receipt of your old column.
Return shipping cost and method is your responsibility. To help keep the price of our columns low, we do not supply return labels.
NO DOWN TIME​
All of our rebuilt Ford steering columns are 'exchange' units, requiring you to send us yours after you install our rebuilt one. Continue using your truck until you get our replacement column, install it and you're back on the road again. Simply return your column in the same box your replacement came in, and your core charge will be refunded.
EASY TO REPLACE!​
Download complete steering column removal instructions here (1980-1991 ONLY).
Having the new rebuilt Ford steering column available before you start your job allows you to compare them to make sure it's right. These columns are held in with 4 bolts to the dash, a shift indicator string, a shift cable, a couple of wire harnesses and 1 bolt for the steering shaft. Simply transfer your column and install your steering wheel and you're done. No complicated processes, no teardown required. That's it!!
Want your rebuilt instead? Send us yours and we can rebuild it for you--72 hour turnaround time.
Click here to read about our steering column rebuilding services
If you have any questions, please either call us (435-319-6011) or submit them through our Contact Page
Click "Order it Now" to view shipping options, pricing & speeds BEFORE you pay
Not Finding What You're Looking For? CALL US at 435-319-6011 --- We like to help!
johnnyreb
West Virginia
1980-1991
  • Non Tilt
  • Upper Bearing
  • Lower Bearing
  • Ignition Actuator
NO DOWN TIME​
EASY TO REPLACE!​
Want your rebuilt instead? Send us yours and we can rebuild it for you--72 hour turnaround time.​
They are good people to deal with.
Motech
Santa Cruz, CA:
Take the steering wheel off and go from their. Alot easier then taking the complete steering column out.
I know how it's done. Just curious for @Dallas82Bronco
With key broke off, can it be turned to run position?
If so, quick release and replacement of lock cylinder from the outside might be possible.
@Dallas82Bronco
This is good advice for that external lock cylinder removal.
Motech
Santa Cruz, CA:
Repair Procedures
IGNITION LOCK REPLACE
Fig. 1 Ignition lock replacement.
Fixed steering column
Fig. 2 Ignition lock replacement.
Tilt steering column
1. Disconnect battery ground cable.
2. Remove steering wheel trim pad and steering wheel.
(NOTE STEP 2 NOT NECESSARY FOR TILT COLUMN)
3. Shift transmission into Park on vehicles with automatic transmission, or into any gear on vehicles with manual transmission.
4. Insert a [1/8] inch diameter wire or small drift punch into retaining pin access slot and remove lock cylinder, Figs. 1 and 2, while depressing pin. The lock cylinder retaining pin is located adjacent to the hazard warning button on models with tilt steering column and inside the column near base of cylinder on models with fixed steering column.
5. To install, turn lock cylinder tbo On position and depress pin.
6. Install lock cylinder into housing. Turn ignition key to Off position after ensuring cylinder is fully seated and aligned into interlocking washer.
7. Turn the key to check for proper operation in all positions.
8. Install steering wheel and trim pad and reconnect battery ground cable.
fred tyler
