fuel odor
Devil Dog08
philadelphia pa
i have been noticing a fuel odor coming from the filler area .after inspecting the area i seen the rubber filler hose has a tear in it where it goes into the tank . can i just undo the hose and replace it say with another rubber hose or is there more to it ? just wondering if it is like changing a radiator hose......thanks
yo
OUR SPONSOR HAS the HOSE;
Item #30218 - New
1980-96 Ford Bronco
12" Hose
http://broncograveyard.com/bronco/i-30218-rear-tank-filler-hose-80-96-bronco.html
$25.00
A source to use ro confirm size;
1987-1996 Ford Bronco (Full Size) Rubber Fuel Filler Hose
Rubber Connection Hose that runs from fuel tank to filler neck.
Fits: 1987-1996 Ford Bronco (FULL SIZE)
Neck Diameter: 2" Inch
Tank Diameter: 2-1/4" Inch
Length:11-12" Inches
Price: $80.00
http://www.fillernecksupply.com/servlet/Categories
Replacement Info; others here in da Zone may help
NO SMOKING OR TROUBLE LIGHTS IN AREA
Fuel Tank Vent Tube Replacement w/plastic flex pipe in a 95; "...i have a rubber hose inside my filler pipe .."
Source: by fordsohc46 at Ford Bronco Zone Forums
http://broncozone.com/topic/19811-slow-to-fuel/page__gopid__104622&
2.Disconnect the negative battery cable.
4.siphon the fuelfrom the tank if full into a suitable container. Remove as much as necessary
6.Loosen the clamps on the fuel filler pipe and vent hose as necessary and disconnect the filler pipe hose and vent hose from the tank.
Replace HOSE & clamps (if damaged or rusted)
87-96 Filler
by Steve
Devil Dog08
Devil Dog08
philadelphia pa
as always thanks for all your help...........oh by the way im really enjoying my back window going up and down and use of the tailgate
Gryph
