yo
OUR SPONSOR HAS the HOSE;
Item #30218 - New
1980-96 Ford Bronco
12" Hose
http://broncograveyard.com/bronco/i-30218-rear-tank-filler-hose-80-96-bronco.html
$25.00
A source to use ro confirm size;
1987-1996 Ford Bronco (Full Size) Rubber Fuel Filler Hose
Rubber Connection Hose that runs from fuel tank to filler neck.
Fits: 1987-1996 Ford Bronco (FULL SIZE)
Neck Diameter: 2" Inch
Tank Diameter: 2-1/4" Inch
Length:11-12" Inches
Price: $80.00
http://www.fillernecksupply.com/servlet/Categories
Replacement Info;
others here in da Zone may help
NO SMOKING OR TROUBLE LIGHTS IN AREA
Fuel Tank
Vent Tube Replacement w/plastic flex pipe in a 95; "...i have a rubber hose inside my filler pipe .."
Source: by fordsohc46 at Ford Bronco Zone Forums
http://broncozone.com/topic/19811-slow-to-fuel/page__gopid__104622&
2.Disconnect the negative battery cable.
4.siphon the fuelfrom the tank if full into a suitable container. Remove as much as necessary
6.Loosen the clamps on the fuel filler pipe and vent hose as necessary and disconnect the filler pipe hose and vent hose from the tank.
Replace HOSE & clamps (if damaged or rusted)
87-96 Filler
by Steve
