genthree
Bronco was running GREAT!!! Then it sat for a couple of weeks while I rebuilt the transfer case.
Started it up and it didn't fire right away and I cranked it a couple of times. It started up and sounded a little weird, the idle smoothed out and I hopped out and walked around to shut the hood. Fuel was dripping off the bottom of the air cleaner!!!! I shut it down and removed the air cleaner and there was fuel all over the top of the intake manifold and running down the fuel line. I cleaned it all up and restarted the truck. It fired right up no issues, walked back around the front and fuel is spraying out of the fitting that connects the rubber hose to the carb, but it is coming out of the threads in the carb itself. It's got big pressure behind it and it was shooting a fine stream 6-8 feet!!!
I am guessing float stuck up or down? Can a fuel pump generate TOO MUCH pressure? Manual choke carb, 2BBL Holley, mechanical pump, new fuel lines, No recent mods to the system.....
Thoughts??? I rebuilt the carb a year ago or so and have had no issues.....
Kinda scary situation..... It would be my luck to finally get it all put back together and have it burn to the ground at a stoplight....
