Door Hinges
DetroitBronco
I have a 96 Bronco. I know my door hinges are worn out. What's the tell tale for whether I need new hinges or just new pins and bushings?
gameshooter
32711[/snapback]
i was tolded that you couldn`t buy bushing for a Ford. the only why you could fix them is to buy new one or used one.hope it helps. if you find out anything abut them let me know. i need to replace the ones on the driver side door.
BRONCFOOT
Newberry, SC
32730[/snapback]
Bushing FORD# D9OZ 6522841 C, forget the pin #,but ones for 86 Mustang will work
32734[/snapback]
yep:
looks like this: Motormite (Dorman, Help, etc. Brands) 38410 Ford Hinge Pin and Bushing Kit - 1 pin, 2 bushings and 1 e-clip. Sizes: .342" x 3.57" (pin), .345" x .480"
http://www.dormanproducts.com/cgi-bin/vm91...ALL&vTime=43787
Application Guide:
http://www.dormanproducts.com/cgi-bin/vm91...ategory_list=:0
http://www.dormanproducts.com/images/items...p1/kit38410.jpg
Also, get their t'gate striker bushings and other door striker bushings.. fits swell!
D
DetroitBronco
Jeff's Bronco Graveyard here in Michigan has the Pin/Bushing kit. I'm just trying to figure out if that will do the trick, or if my hinges are hosed too.
sandmann999
Abandoned Bronco
Moscow, ID
Is there any way to replace the spring (the one that keeps the door from falling closed and looks like a big S) without replacing the hinge? Mine snapped in half.
32756[/snapback]
never saw this, but worth a look:
Hinge Spring 38435
Fits Ford cars & trucks 1997-80. Bolts on to hinge to repair weak or broken springs without removing door. Includes hardware to install. Not available separately from the dealer.
Applications:
http://www.dormanproducts.com/cgi-bin/vm91...egory_list=:0:0
try this too; ask the company if this is for your bronco:
http://www.atrim.com/Page157.html #A14555
looks close according to this diagram:
http://aarc.epnet.com/application/8576/857...rglass_Roof.htm
go to BODY AND TRIm
EXTERIOR
DOORS
ADJUSTMENT
or go to local parts place or auto body repair shop and ask for the spring, etc.
32752[/snapback]
usually the pin/bushing goes South due to crud & lack of ****; we use lithium grease
eholt80
