clutch
bigbronco82
az
Whats going on everyone
I have an 82 big bronco, and i was just curious, my clutch is the manual linkage, the whole spring setup with that mushroom head looking metal linkage. is there a way or kit for a possible switch to go hydraulic, only cause it is hard as **** to engage the clutch. it isnt that bad, im just wondering thats all. thx
I don't think I have ever seen a kit any where but you could most likely put the hydrulic clutch on from a doner truck.
bigbronco82
az
damn, just curious, ya never know what is out there. thx anyways
cjbronco
Jersey Shore
I am currently collecting all of the parts that are needed to do this swap on my 82' You need a clutch pedal and shaft from an 84-86 f150-350 or bronco. Then you need a bellhousing with an external boss attached for the external ***** cylinder. Then you need the correct master cylinder and ***** cylinder and lines for your peticular tranny. Ill let you know how mine turns out. If you have any questions just ask. See, I am swapping in a ZF tranny so I need a couple different parts than you will need.
eholt80
