Check engine light is on
buckleywarrior02
Arvada, Colorado
I bought my Bronco about a year ago and when I bought it, the check engine light was always on. The previous owner said he wasn't sure what it was but it ran fine and he was right. So, I took it to my buddy's shop and we ran the code and it came up "Heater O2 sensor". We all scratched our heads and weren't sure what that meant. I left it alone because it's been ok to drive, but I'm starting to think that it may be the cause of a few issues I have. If I'm going up a large grade, sometimes and I mean SOMETIMES it'll kick down to the secondaries and even worse other times she won't even kick down and I'm just cuggin' along. Anyone know what it could be?
Also, I plan to do my exhaust here real soon, so maybe that'll help. Where have some of you purchased your exhaust parts(aside from summit and jegs). I need th know where to get the y-pipe.
Thanks in advance and sorry about the long post :blush:
Our 96's have 4 Oxygen Sensors; do you still have the Code?
if not,a guess, most likely the O2 sensor on driver's side exhaust manifold is the bad one. These usually go first. See figure1 in this:
DRIVEABILITY - HO2S (HEATED OXYGEN SENSOR), CATALYST, AND FUEL SYSTEM MONITORS - SERVICE TIPS - OBD II VEHICLES ONLY - 96 Bronco, TSB 01-9-7 Source: by Ford via Ryan M
Note that a few things could cause an 02 sensor to fail,but that one went bad @ 70k miles in my 96.
Exhaust; I've been shopping for a stock muffler/tailpipe and found that Walker makes an exact fit for both incl. hangers; they have the aluminized version that will last longer than the plain steel types. Advance Auto Parts isslightly less $ than NAPA.
Walker Y pipe; Walker makes a replacement setup for the 5.0 and 5.8's , its a new Y pipe and a single converter with a air tube kit included,alto I did not see it in their on-line catalog
Walker muffler 18367 $112.88 Advance Auto
Quiet-Flow 3 Muffler; Requires 35502; If Welded Assembly, Replace All Required Parts; Note: If muffler has removable shield, reuse O.E. shield w/35564 strap clamp. If not reusable, use 35567 shield w/Two 35564 strap clamps.
Warranty: Lifetime Replacement Warranty
Body Cross Section Diameter:7"
Body Configuration:2"
Body Length:29 1/4"
Inlet I.D.:2 1/4"
Outlet I.D.:2 1/4"
Overall Length:25"
http://www.partsamerica.com/ProductDetail....=15&PTSet=A
Type your zip code in for a price
Features & Benefits:premium product designed for O.E. equivalent Sound and precision fit. New CF technology helps resist rust through and improve durability.
walker tail pipe 45860 $17.87
Features & Benefits:Aluminized Material
OE Fit
Outlet Configuration:2 1/4" OD
Length:47"
Standard Hanger
528920 $4.19
rubber oval donut 2 holes on top sides and one vertical rectangular hole
http://www.partsamerica.com/product_images.../mar/528920.jpg
buckleywarrior02
buckleywarrior02
Arvada, Colorado
yo,Our 96's have 4 Oxygen Sensors; do you still have the Code?
Body Length:29 1/4"
Inlet I.D.:2 1/4"
Outlet I.D.:2 1/4"
Overall Length:25"
OE Fit
Length:47"
Standard Hanger
528920 $4.19
So I'm assuming that when I do my exhaust I should replace them all? I wish I still had the code but I do remember it saying hearted O2 sensor.
And as far as the exhaust upgrade, I need to know where to get a 3" y-pipe and also what most people see as the best hi-flow cats.
Coastersfwb
