c6 transmission
gibs0n06
independece,mo
im getting ready to put a c6 in my bronco it came with a manual but goin to auto for city driving will the transfercase on my manual trans work on my c6 and what else will i need to do for the swap
thanks
andrew
im getting ready to put a c6 in my bronco it came with a manual but goin to auto for city driving will the transfercase on my manual trans work on my c6 and what else will i need to do for the swapthanks
andrew
Your existing transfer case *should* work but as I recall what you'll need to do is to be sure you have a 4x4 transmission with a tailshaft that mates. You can't use any ole' C6, it needs to be from a 4x4 and it needs to have an output shaft that fits the NP205 (or 203 if you have full-time 4wd)
Bronco Phil
webberville michigan
you also have to change the small bar from the two rods coming out of the transfer case straight bar for autos and z bar for stick shift
