bronco II plug fire
deogolf
Need help! 86 bronco II. I have fire to the distributor. Distributor and module are new. No fire to the plugs. Two fuel pumps. Both work, but are straight wired to a manual toggle switch. Any suggestions? Thanks
D
deogolf
did you replace the wires? did you replace the whole dristributor or just the cap?
hi, thanks for the reply. sorry, haven't had time to work on this vehicle in a while. yes, the whole distributor and module is new. any ideas of what to check next? anybody? thanks.
mauser1111
I'm having the same problem, but I replaced just about every ignition compnent and now Im on replacing the sensors. I tried replacing the rotor button again and then it fired and ran, bu when It got warmed up it shut off again. I need to replace the EVP sensor on mine agin because it was junk, but Im stumped too.
I know you said you replaced the ignition module, are you referring to the pick up coil inside the distributor under the rotor? If not, that is a classic symptom of a bad pick up coil. They run fine until the engine warms up and then it is like someone reached over your shoulder and turned off the key.
kyleh01
