I didnt lift mine front to back.Thats too much weight.I lifted mine with a floor jack and a 4x4 piece of wood and did it 1 side at a time.I took out the fan shroud,took out all the bolts on the side you want to do first.Then replaced the bushings and then put in the body lift blocks.Drop the correct size bolts through.Then I repeated for the other side.Once all the bolts are through, start tighting them all down.Also If you have an automatic,Disconnect your shift linkage before lifting the body.And instead of hacking the fan shroud,I redrill the radiator mounting holes 3 inchs down to drop the rad down 3 inchs.Then theres just reinstalling your shroud and lengthing your shift rod.And just to let you know I installed the poly bushings in place of the rubber mounts.What I ran into was the 4 mounts rivited to the frame for the mounts were rusted bigger than the new smaller poly bushings.I had to get those oversized washers from bronco graveyard called frame savers,and weld them to the mounts.So check that before you expect to just take out the old bushings and install new ones,Cause it wasted my time when I came across it...
