BroncDaBronc
I have a 1995 Bronco with a 351, E4OD, Electronic shift transfer case. My speedometer does not work, Transmission has gone into limp mode and i keep blowing the ABS fuse (# 5 in the underhood box). Recently I changed the oil pan, pump, timing cover, w-pump, and all 3 ABS sensors. I found a towing harness stuffed up above the gas tank and have inspected that for shorts. The fuse does not blow when i go into reverse, but does while driving under normal conditions. It started happening while driving down the road at 45 mph. I have no idea where to begin looking next for this short. Any help would be greatly appreciated.
