Jhill45
Whats up everybody. "Long time listener, first time caller" brand new here. Alright so heres what im working with. Ive got a 93 f150 and did the sd to maf conversion. I pulled the whole engine bay harness from a 95 bronco maf 5.8 along with eec.
I also have bolted up a e4od out of a diesel.
Isses I am having since swap was done is hard shifts, no speedo and wipers dont work. Im sure tyeres other issues Ill find and repair along the way. Hoping for a bit of guidance in remedying this issue. Plan of attack
1. Make any pinout changes and trans connector if there needs to be with diesel trans and 95 bronco harness/eec
2. Because i changed the harness and eec Im assuming those pinouts would remain as they are, correct?
3. Firewall connections c202 and c205 pinout changes between 93 f series and 95 bronco
Does anybody happen to have a schematic diagram with color and purpose for both the c202 and c205 for. Both of these yrs? Thank you in advance. Want to get old blue running smooth again.
