94' Bronco High Flow Exhaust=Larger Injectors ?
Ozark Hauler
In a "Holler" S.W. Missouri
I ordered my new engine yesterday . While it's apart it's getting new injectors , high flow catalytic converter, single in/dual out (3" (?) in /2.5" out) .
It looks like I have the 19 lb. Orange Tops So that's what I got this time as well .
If I go to a larger exhaust will I run lean , or should I have gone a step larger (22.5lb./hr) ?
I drive easy (sometimes) , and I don't do the "Ricky-Racer" thing. But I work this truck for sure .
My Bronco got close to 400 miles on a tank .I would like to keep it in that area with the new engine .
Thanks,
Steve
Ozark Hauler
Ozark Hauler
Thanks ! I got the new engine yesterday and it's almost back together . Then on to replacing the Injector harness on 3 cylinders ,along with another plug , and finally the vacuum lines .
The Bronco will be getting a new exhaust system . It's got the oem system still in place but a big dose of Sawzall will cure that ailment !! . It'll be great getting back on the road . That's our primary truck for hauling and emergencies .
Steve
mbtech2003
cape cod, mass
if your getting the same sized engine with the same compression ratio the the stock injectors will be just fine. no need to over enrich the mixture btw i have stock injectors in my truck.
Coastersfwb
