kevin b
I got the push button shifter in my bronco and read that I could engage up to 45 or 55mph but every time I try while I am moving usaly below 15mph It dosn't engage
Any ideas?
Any ideas?
u tryin to engage 4 high or 4 low?I got the push button shifter in my bronco and read that I could engage up to 45 or 55mph but every time I try while I am moving usaly below 15mph It dosn't engage
Any ideas?
33152[/snapback]
Take the auto hub cover off & check inside visually for crude, etc. Only non-damage/contamination thing I can think of now is if you had it in 4x4 before you stopped; then backed-up, say over 10 feet; the auto hubs would then disengage and take a little time to engage again after you pressed the 4z4 button and get up to speed.I got the push button shifter in my bronco and read that I could engage up to 45 or 55mph but every time I try while I am moving usaly below 15mph It dosn't engage
Any ideas?
33152[/snapback]
33199[/snapback]
Just to get some info while the on the subject. For an '81 with manual hubs, if they're locked, what's the highest speed one could shift from 2H to 4H?4x4 high But you guys wont be leave this I was looking for a place to run a rc car of mine when run into so mud whiel moving pressed the 4x4 button and it engaged first time it has since I got the truck and does it every time now. thanks for all your help everyone
33436[/snapback]
