BroncoJoe19
I have a '90 bronco with an E4OD and sometimes I have to hold the shifter high up into park for it to crank.
It's not my DD and I hardly ever use it, so its not real high on my list of things to take care of, but if I remember correctly my haynes manual said that it may be due to a worn linkage. I looked quickly underneath, and didn't have a helper to wiggle it from above, and I gave up.
Again looking at it quickly I didn't see anywhere to make an actual adjustment. Is there a way to adjust it the linkage?
IN this thread
http://broncozone.com/forums/index.php?s=&...st&p=100225
Steve posted a pic of a MLPS with a note of where it is to be adjusted.
Miesk5 stated where I can find additonal info on his site.
So what's the scoop? Without seeing it...
is it likely to be that the linkage is worn, and needs to be replaced.
The MLPS can be adjusted to take out any slack,
The MLPS is getting ******* and I should consider replacing it before I lift the shifter and it still doesn't crank.
Yeah... I know you'd need a crystal ball to see how worn, but I figured, I've seen dumber questions on here.
IN this thread
