1987 Broncoii wont start
toddinav
1987 4x4 Broncoii 2.9 fuel inj.
Here's my problem: Found burnt Fusible link(orange stripe on black wire) Fixed and checked Fusible link. The engine would start...then would die after a couple min, and wouldn't restart till it sat for an hour. Now engine will turn over, BUT WILL NOT START at all. I listened at the gas filler..no noise of fuel pump while key is on. PLEASE HELP
andre
gatineau hill quebec
do u hear relay click when u start
there 1 efi and 1 for fuel pump
ford relay do corode alot pull relay check connector
f150. bronco 2. rager all have that prom
bad connecsion will burn link
donlightbody
fuel inertia cutoff switch can cause that symptom also, I been through that one. replaced the relay, and both fuel pumps before I figured it out
plumberdoode
southern MD
1987 4x4 Broncoii 2.9 fuel inj.Here's my problem: Found burnt Fusible link(orange stripe on black wire) Fixed and checked Fusible link. The engine would start...then would die after a couple min, and wouldn't restart till it sat for an hour. Now engine will turn over, BUT WILL NOT START at all. I listened at the gas filler..no noise of fuel pump while key is on. PLEASE HELP
try replacing your electronic engine control relay
kyleh01
