Tranny slips when cold....sometimes
hoghappy
The Heart of Dixie
I'm sure the answer to this is already in here somewhere...but I going to ask anyway. Sometimes my tranny acts like it's jumping out of gear. You can see the tach go up and hear the motor rev. Then it will pop back into gear. After awhile it quit acting up. It only seems to do it after it has not been driven for awhile...and it doesn't always do it.
Is it terminal or just a sensor?
Thanks
hoghappy
hoghappy
The Heart of Dixie
yo!Is the Transmission Control Indicator Lamp (TCIL) Flashing ?
Is there a Check Engine Light?
Check for Codes anyway; Self Test by BroncoJoe19
Report back with any Codes.
Remember to have engine @ Normal Operating Temperature before doing the KOER portion
No lights come on. I will have to wait till I get a new radiator in to check codes at operating temp. Cheap Ford (just like most of them out there now) plastic radiator cracked. I'm replacing with a all metal one hopefully this weekend if it's warm enough outside. It only does this sometimes and then when it does it, doesn't matter what gear it's in. It can do it in 1st or at speed in OD. It just jumps into a neutral spot. But when it catches the gear...it can be a little hard if I am on the throttle. Sometimes it will jump in and out several times before it settles down....then it won't do it for the rest of the day.
