yo!
What year and engine do you have?
Some info for you;
1st, Find another shop
Swap, 2 to 1 Advice Source: by Froggmann (Ken P) at froggmann.com
"I have two cats on my Bronco, can I replace them with one?
A: Technically, no. Realisticly, yes.
Explanation: It is illegal to replace or modify emmisions control equipment with other-than-stock equipment. But the pre-cats are only there to reduce emmissions until the main cat gets warmed up. So yes, you can go to one cat and you might even burn cleaner with a aftermarket high-flow cat. But you will run the risk of not passing visual inspection..."
It may not be a prob now, but since you may be in another state someday with the Bronco.... esp NJ!
Ck for prices elsewhere, such as:
all-catalytic-converters.com - Bronco/Ford truck catalytic converters; diagrams & dimensions
an example;
Magnaflow Catalytic Converter: 1987 - 1993 Ford Bronco
Notes: CATALYTIC CONVERTER, 93500 SERIES, UNIVERSAL FIT -- Catalytic Converter, Front And Rear, Non-OBD II UNIVERSAL Single Air Tube , May Require Cutting And/Or Welding
Chassis-Engine
:Bronco 4.9L, 6 Cylinder, Gas, MFI, VIN "Y"
:Bronco 5.0L, V8, Gas, MFI, VIN "N"
:Bronco 5.8L, V8 Windsor, Gas, MFI, VIN "H"
Your Price: $115.29
Notes: CATALYTIC CONVERTER, 94000 SERIES, UNIVERSAL FIT -- Catalytic Converter, Front Or Rear, OBD II Compliant UNIVERSAL Standard Oval, 2.5" In Or Out, 4" Tall, 6.5" Wide, 12" Body Or 16" Overall Length, May Require Cutting And/Or Welding
Chassis-Engine
Your Price $78.40
read this by all-catalytic-converters.com
How do I know if my catalytic converter is defective?
Also, do you have a Check Engine Light ON?
let us know!
