Spare tire carrier damage
MotorBaby
Near Atlanta, GA
Hey everyone! I got a '93 Bronc (named Bradley) last January. The interior was/is immaculate but the exterior needed a little TLC. Hubby (the other guy in my life) finally gave me the green light to get him painted with one stipulation: I have to find some way to keep the spare tire carrier from extending all the way and causing damage to the rear quarterpanel (again). It was damaged when I got the truck and I'm going to have it repaired when I get him painted. Anyone know of any way to keep that from happening again? Please hurry, for I'm ready to make Bradley beautiful ASAP. Thanks.
MotorBaby
MotorBaby
Near Atlanta, GA
Sorry, Dude. Mine is a boy. We have too much fun together and we make my husband too jealous for him to be a "her." Any suggestions on my damage-prevention?
The only way to guarantee no damage is to remove it and put in an internal tire carrier.
Broncosaurus!
Oshkosh WI
Mine has a stopping point, it is built into the mount hinges. Not sure why yours does not have that stopping point. A limiting cable or strap is the only other way I can think to fix it. Or weld an upright arm off the bumper. Or weld something off of one or both hinges.
bluesman17
Spam Terminator
South Bend, Indiana
Id say go with the welding thing too, a body shop should do that CHEAP just have them put a little stud on it to stop it from swinging that far
MotorBaby
MotorBaby
Near Atlanta, GA
Apparently the one of the previous owners caught it on something while it was fully extended and that caused the body to bend. I'm trying to avoid a reoccurance of that. I was thinking of reinforcement of that corner of the body, if that's possible..
Depending on your fab skills, any mods will have to be from the inside of the quarter panel. If you remove the top you can easily get to the inner panel and build a subframe in there. Make sense? Or am I babbling? Once the subframe is built I would go with a limiting strap or welding a tab so that the carrier doesnt swing out to far. You might have to cut some of the inner quarter panel out to reach where you need to modify, but if you are able to do the work I suggested so far, then welding the cutout back in will be a snap.
MotorBaby
MotorBaby
Near Atlanta, GA
The subframe idea makes complete sense to me; as a matter of fact, that was the kind of thing I had in mind. Hubby likes the idea of a welding tab, so I guess between the two, we'll come up with something. Thanks all for the input. Wish me luck!
Broncosaurus!
Oshkosh WI
To prevent that, don't drive while the tire gate is unlocked, I thought you meant that it swung out like 270 degrees and hit the quarter panel
davids78bronco
fabricator extraordinaire
central Oregon
Putting in a 'subframe' is going to be costly, and time consuming. Either find an inside tire mount, or buy an aftermarket style rear bumper with the tire carrier incorporated into it - the bumper's your best bet
Wdtdls
