What Dana 30 Gears??
ibgeekn
Rebuilding a Dana 30 front, stock 41.10 gears. Question is what type would I have? This is a '66 with everything stock. Finding mentions of a 'reverse' gear set. And gear sets with TJ listed, etc.
If ordering from a supplier what would we be telling them?
Reverse gear sets are for Differentials that have units available for front and rear applications. If its for the front you will need a reverse gear set. But you shouldnt have to worry too much about how you ask, just tell them the ratio you want, the year, and what diff they are.
I
ibgeekn
Thanks for the excellent response. Reason I ask is I've been offered a set but didn't know if rear would work for front. Now I know.......... Ours has a couple of chips in the ring, been there for many years. Don't do heavy off roading, just wander a bit here in Missouri, so not really sure if we want to spend the bucks to replace, or just go for the bearings replacement.
hlt75
the r is for reverse rotation which is used in high pinion setups. your bronco should not need the reverse rotation and a set from the a rear end would work but broncos don't have dana 30 in the rear. maybe a jeep or scout.
eholt80
