RetiredAFSpouse
I have owned this 93 Bronco 5.0 with E04D tranny for 4 years. Everytime I turn around something is wrong with it. This is all that has been replaced.
Spark plug and wires, distributor cap and rotor, EGR valve and sensor, Idle control, new column, ignition switch, fuel filter, alternator, battery, starter, new vacuum lines, neutral safety switch (2 years old) throttle body sensor and motorcraft Solenoid (only 4 months old).
Issues now; at start up will idle to 2500 rpms, then down to 1500 and settles about 1000 to 900. No check engine light. Back out the driveway then start to go forward hear what sounds like a vacuum leak right behind drivers dash. The brake booster has a brand new hose. The noise goes away when driving.
NEW issue: Drive the bronco and make two stops. Get back in go to start. Nothing. ABS light comes on, no check engine light, but battery light shining. No clicking. Keep ignition key on, get a screwdriver and bridge the selenoid, starts right up. This thing has gone to the shop 5 times to figure stuff out. I am trying to fix stuff myself since my husband is never home and he gets very ticked every time it breaks down. Here is a video of the noise behind the drivers side dash. I put the phone on the dash and recorded it.
