Speed (cruise) control trouble shooting
Guillermo
Ohio
I am in the process of trouble shooting the speed control issue and wanted to get some feedback from the forum.
The recall was done by myself. I have gone down this list and the only issue I could see was the less than 1 ohm with the "off depressed"(1.8). Everything else checked out. Not sure if that is the speed control button or what.
Yo Guillermo,
If you still have concerns whatsoever about Speed Control Recalls, please contact the Ford Customer Relationship Center:
... have VIN ready.
Fuse 13 Blown, Stop & Hazard Lamps, Stop Sensor for Anti-Lock Brakes (ABS) Speed Control & PCM Short Circuits, Common Locations TSB 95-02-11 for 94-95 Bronco & F Series; See the location diagram
Source: by Ford via Chilton
Significant Excerpts:
"The recall was done by myself. I have gone down this list and the only issue I could see was the less than 1 ohm with the "off depressed"(1.8). Everything else checked out. Not sure if that is the speed control button or what."
1.8 ohms could be caused by corroded connector terminals or what Ford describes as terminal back-out, etc.
G
Guillermo
Ohio
Yo Guillermo,
... have VIN ready.
Thank you for the info sir. I’ll report back.
G
Guillermo
Ohio
Yo Guillermo,
... have VIN ready.
Hey Al,
I have a question: does the airbag module need to be hooked up for the speed control to work?
sinker4
If you replaced any break light bulbs with LED replacements then the cruise wont work. It need the resistance in the standard bulbs.
G
Guillermo
Ohio
G
Guillermo
Ohio
An update:
> All the fuses are good.
> Clock spring is good
> Horn and airbag work.
> Continuity to the servo is good.
> Speedometer/odometer work.
> No abs lights
I *think* I'm running out of electrical options and the issue might be mechanical. Perhaps the speed module itself? I've checked the cable wheel, it turns. But this is a 27 yr old vehicle and perhaps it's toast? Thoughts.
An update:
> No abs lights
Concentrate on the Servo. See this troubleshooting version in 96 Bronco Workshop Manual @ http://www.diesel-dave.com/vehic/manual/stj/stja3005.htm#a
G
Guillermo
Ohio
Yo G,
And right below the resistance tests, see info about rotating the steering wheel...
Quick question Al: where is G200. I'm also looking into the s216 (splice, switch?). Thank you sir.
Yo G,
G200 pic in lower side of passenger side plastic kick panel with green *****.
Pic is titled, "1356 Electric Shift Control Module Location pic; as Steve3 pointed-out, "...The module I MIS-labelled as "Airbag" is actually the Wiper Control Module (WCM). The Airbag Diagnostic Module (ADM) is light blue, wrapped in black foam, above the gas pedal..." Fireguy50 pointed out the error.
Gary wilder
