New member in BZ
Guillermo
Ohio
Greetings,
I have owned several Broncos and currently in the process of cleaning up a 94' XLT (5.8l with 190k miles). I'd like to clean up the small issues myself and eventually move on to paint, lift, rims and tires.
I am in the process of trouble shooting the speed control issue and wanted to get some feedback from the forum.
The recall was done by myself. I have gone down this list and the only issue I could see was the less than 1 ohm with the "off depressed"(1.8). Everything else checked out. Not sure if that is the speed control button or what. Feedback is appreciated. Thanks!
The project:
I had to pull the horn cover and clean the contacts on my buttons and one point.
They still act up but repeated attempts to turn it on usually works.
G
Guillermo
Ohio
Is there a release on the switches? I didn't see any at first glance. Thank you for the feedback
I was thinking they are ******* on from the back, can't honestly remember. You have air bag?
G
Guillermo
Ohio
Yes I do.The airbag comes out with a 10mm socket. I was referring to the plastic buttons.
I don't have an airbag so going to be a little different.
Yo Guillermo,
I responded to your speed control post at https://www.broncozone.com/threads/speed-cruise-control-trouble-shooting.27389/
If you still have concerns about the speed control Recalls, please contact the Ford Customer Relationship Center:
... have VIN ready.
94 Bronco partial EVTM including Speed Control @ 1996 Ford Bronco '94 EVTM pictures, videos, and sounds | SuperMotors.net by Mikey350
1994 Bronco Dealer Brochure by Ford via Dezo's Garage @ https://www.xr793.com/wp-content/uploads/2020/07/1994-Ford-Bronco.pdf
1994 Bronco Brochure, Partial; Cover & Page 3; plus pics of EDDIE BAUER model accessories.
by Ford via BigRob at 1994 Ford Bronco Bronco Accessories pictures, videos, and sounds | SuperMotors.net
Haynes Red Manual for 80-95 Bronco & F Series @ Hanes guide 80-96 bko f series.pdf via BroncMom
Greetings,
The project:
View attachment 27992View attachment 27993
Welcome to the forum. I,m sure you,ll find alot of people hear will help you with about any problems you may have. Good looking ride. What part of Ohio you at?
david@holycitytransportat
