Yo Chris,
New harnesses may still be sold at
https://www.ronfrancis.com/products.asp?dept=291
WE HAVE MOVED!!! Our address is same as Ron Francis Wiring: The Detail Zone, 200 Keystone Road, Chester, PA 19013
Ask if they still carry the original Detail Zone: 1988 FORD 302/351/460 TRUCK INJECTOR HARNESS
This is a direct fit replacement for the injection harness found on 1988 Ford Bronco, F-150 and F-250. Harness is correctly dimensioned and finished with correct coverings and harness wrap tape. Includes connections for injectors, throttle position, idle speed control and coolant temp sensors. Fits 302 (5.0), 351 (5.8) and 460 (7.5) engines.
Or;
Description | Part # | |
1988 Ford Truck Engine Harness | FH-I460 | |
1989 FORD 302/351 TRUCK ENGINE HARNESS
This is a direct fit replacement for the engine harness found on 1989 Ford Bronco, F-150 and F-250. Harness is correctly dimensioned and finished with correct coverings and harness wrap tape. Fits 302 (5.0) and 351 (5.8) engines.
1989 Ford Truck Engine Harness | FH-50T | |
FORD TRUCK 2G ALTERNATOR HARNESS
Replace your deteriorated factory alternator harness with this direct replacement. Fits 1988 to 1991 Bronco and F-Series.
Ford Truck 2G Alt Harness | FH-T2G | |
Hollander
Quality Replacement Parts | Find Used Auto Parts | Online Locator
The Hollander Interchange provides auto recyclers and auto collectors, rebuilders, and others with the easiest and most comprehensive solution for identifying interchangeable auto parts..." See their yard Directory @
Seller Directory | Used Auto Parts | Hollanderparts
Can select a certain part; Search: 1988 >Ford > Bronco > Electrical > Engine Wire Harness > Alternate Engine Wire Harness
results with call for prices, andinfo such as transmission type, etc;
Winston Auto Wrecking
390 SE Main Winston, OR 97496
541-679-5625
BS Auto Salvage
3637 South Hwy 301 Wildwood, FL 34785
352-748-1150
C & L Auto Dismantling
3413 Edison Hwy Bakersfield, CA 93307
661-366-7710
Farritor Auto Parts
1654 Soth 'E' Broken Bow, NE 68822
308-872-6411
Here's the 1988 Dealer Brochure by Ford via Edwin Storm @
Hot Cars
Register with VIN to see most Ford dealer maintenance/repairs done @ any dealership nation-wide @
Welcome to Ford Owner | Official Ford Owner Site
