Wont go into park...
Middaymassacre
Houston, TX
I went to go and hook up my transmission shifter lines and my column was stuck in park (nothing hooked up to the trans at this point).. so i pulled as hard as i couldand it finally popped out and now it wont go back into park... has anyone had this problem before? also i pulled my steering wheel off... do i need a puller to get to the actual column?? do they sell these at auto parts stores?? thanks.
bidibronco
Norfolk Va
I would double check to make sure your ignition is OFF. If the ignition is in any other position it wont let the truck shift to park.
Johnny Reb
West Virginia
you might also want to check the valve that goes into your brake booster-they will go bad and they don,y=t cost much.
fred tyler
