will a 302 fit without custom work?
trains11tjc
Tomball
ok well my grandpa says he thinks my 302 wont fit in my engine compartment without custom work...i know many people have done it so im not sure if it might be different cuz mines a 66 and they didnt offer a 302 in the 66's...u guys know anything about it...will i have to do custom work?
STLKIKN
Calgary Alberta
It will fit, the engine bay didn't change when they added the 289 so it depends on what you call "custom"
You will need;
bigger rad
V-8 tranny and bellhousing
V-8 motor mounts and towers (the towers are welded to the frame)
V-8 clutch linkage
exhaust manifolds and full exhaust
302 complete with all accessories, pulleys, flywheel, clutch assembly.
There may be a couple of other minor things I have failed to remember, but that should give you a good place to start your parts hunting.
T
trains11tjc
Tomball
You will need;
bigger rad
V-8 clutch linkage
thanks for the help...so pretty much towers are the only thing you have to weld? right?
