What tires for my 1994 Eddie Bauer? with no lift!
Hawkeye75
What size and brand of tires do you all recommend for my stock 1994 Eddie Bauer Bronco? Most of the time I will be on pavement but I will hit dirt. I have plans to replace the stock shocks, but no plans to lift it much if at all.
Thanks for any info from Tony in Boise Idaho
32 or 33 11.50's; just trim black valence a bit. No radius arm scrub; 33's may need bumper mod w/washers to avoid slight scrub.
Had 32"GY Wrangler ATs for dd and over-sand use; wore well; better than stock, still bad in rain tho; went to 32 11.50 Dayton Timberline AT last year; mucho better in rain and snow; better ride as well; less harshness over potholes, etc. better in sand too.
Reset your PSOM with the 32 or 33's tho;
PSOM Recalibration on a 93 by Muddybronco
http://www.arkansasmud.com/psomcalc.html
Measure tire diameter/radius w/normal PSI and off ground; bec. tire sizes vary from published info.
Coastersfwb
