What is that?
laborrega
Any help is greatly appreciated.
I don't see anything connected to it, rather some sort of dry rotted black tube/cable that is cut.
yo laborrega,
Sure appears to be the Under Hood Reel Light
But, It probably has Mercury in it;
Under-Hood, Mercury Removal Guide, Bronco, Ford, 70-95, etc.
Source: by wa.gov/pubs http://www.ecy.wa.gov/pubs/0504024.pdf
excerpts;
"According to industry representatives, any vehicle equipped with a convenience
light in the hood and/or trunk is likely to have mercury switches if it is a:
1. 2002 or older model made by Ford or General Motors; or
2. 1998 or older model made by Chrysler..."
But they forgot to list our Broncos, but did show Bronco II and F Series
Also included are da Anti-lock braking systems (ABS) on some 4-wheel drive vehicles contain mercury switches. The switches are in a G-Force sensor that detects deceleration and takes the vehicle out of 4-wheel drive during slipping. Broncos from 92-96
L
laborrega
The item I am referring to is behind the blower. I tried putting a red box around it. It's not on the hood, but rather in the engine bay right behind the blower. I'll try to get a better picture.
Thanks Miesk5
Elmo
Forsyth Georgia
It is the vacume actuator for the heater. it opens the door for freshair to come in from outside closes the door when MAX A/C is selected.
awww...ok
As ELMO advised; Floor/Defrost Door Vacuum Moto, Ford now decsribes it as da Outside Recirculate Door Vacuum Motor
Door Locations in Parts Break-Out Diagram in 80-86; temperature blend door, vacuum motors, heater core, upper & lower plenum depictions, etc.
Source: by HawkRdr at SuperMotors.net
Floor/Defrost Vacuum Motor Location Depiction in 80-86
Source: by Steve83 (Steve, That dirty old truck) at SuperMotors.net
Is your Defrost on All the time?
L
laborrega
Thanks guys ... i'll have to figure out how to get it to work.
Right now none of the AC system works. Nothing happens when I turn the AC on. Not even the blower.
thanks!
L
laborrega
I tried all the functions heat, vent, AC no luck.
Weird thing is everything else works, even the cruise control.
The only other thing that appears not to be working is the 12V adapter/lighter.
All the fuses under the dash seem to be OK, I checked them visually 1 by 1.
Thank you for the diagram. I'll dig further and let you know the outcome.
yo laborrega,
Hopefully you have a 12v test light or multimeter to ck the ckts; also pull & ck heater fuse for continuity
Coastersfwb
