Transmission troubles??
mkg230
Hey, everyone I'm a new member of this post but a long time reader. I just a 90 Bronco 5.0L and AOD. My problem is this: at speed when I push down the gas peddle it feels like the transmission is bucking wildly (like what you would expect if you had the gas peddle to the floor going up a steap hill) and there is a metal crashing sound. Some times this will happen from a dead stop if I accelerate to fast. Any advise would be greatly appriciated.
Thank you,
Matthew Gray :)>-
BLADE262US
Michigan
Are you sure its the tranny ? I would look closely at the rear axle u bolts and the spring perches for any damage . :D /emoticons/[email protected] 2x" width="20" height="20" />
M
mkg230
:wacko:
32671[/snapback]
Since the time that i have posted I've found that the throttle position sensor, vehical speed sensor, and the EGR valve sensor are all bad. hopefully, that is why the tranny is kicking. I haven't checked the U-joints but i will this weekend. Thanks
