Transmission and Engine Options
BroncoLoverTNT
Hello Everyone,
I wanted to know if it's possible to take out an automatic transmission and replace it with a manual? Will I need a lot of conversion parts for the engine as well or should I put it off until I can put a new engine and trans in? Eventually I will need a new engine. I have a 1992 Bronco with the 5.8L 351 engine. I just don't want to replace it and then find out I can't convert to a manual trans. Just to fore warn anyone replying; I only have basic knowledge of auto's. I usually learn as I go.
ocalabronco
ocala, Fl
you can swap out an auto tranny for a manual. infact, its a swap im looking to do very soon. the E40D, which you should have too, isnt a bad tranny but for the wheeling i do, it takes a bad beating and doesnt like it too much. basically if you get a tranny with mechanical clutch engagement, you'll have to get the clutch fork and all the linkage that goes with it. if its hydraulic engagement (like say ZF 5 spd), you need the master and ***** cylinder to engage the clutch. i'm still learning about this as i go too. but im tired of mucking with an electronic auto
Here are some swaps for you:
M5OD Swap for 92-96 w/parts list (ZF Swaps are listed below) by Havack (Ben) at broncodata.com
ZF Swap Parts List (M5OD Swap is shown above) by Franklin at FSB Forums fullsizebronco.com
ZF Swap, pics in a 95 (M5OD Swap is shown above) by Superjet (Pile) at SuperFord.org
ZF Swap, pics in a 90 (M5OD Swap is shown above) by My90Bronco at SuperFord.org
ZF Swap, pics, (M5OD Swap is shown above) from a 96 F350 in a 95 by Pepper (Big Pig) at SuperFord.org
My Webpage
Hello Everyone,
28837[/snapback]
madmax
quakertown pa
sorry to be bringing up an old thread but does anybody know if the newer zf 6 speed trans will bolt up to a 351W? Or will i have to cut off the built in bellhousing and weld on something that will fit?
alternatley is it possible to re gear the zf5 so that 1st is no longer a creeper? say instead of 5.72 2.94 1.61 1 0.76 change first to 3.5 or so and then go with a steeper rear gear like a 3.55 instead of a 4.10
JohnK
