Transfer case location
old yellow stud
LakeBay, Washington
Hi everyone I have a question. I am going to put the NP435 and the Dana 20 transfer case in my 71 hopefully this weekend. I have everything out of the donor bronco and am going to try and pull my old 3 speed out tomorrow. My question is will the orginal location of my transfer case change? Now that I am putting in the NP435. The one out of the donor bronco is dual shift and the transfer case is messed up anyway so I really can't use it so I am going to use mine. Mine has the orginal singal shift. Actualy one more question while I am thinking about it. When I removed the old T-case from the adapter and put mine on it does anyone know what I can do for a gasket between the T- case and the adapter or is there one?
Thanks,
Dwain
welndmn
Thanks,
Dwain
31199[/snapback]
Just use silcone.
And the T-case will/wont move depending on what adapter you have to connect the 435 to the 20.
If you have an AA adapter, the t-case stays in the same spot.
Sandoval_broncosauria
