To cut or not to cut
gnylan1
I have just bought an uncut, clean bronco, no rust around the door jams, wheel wells or tailgate. I am still investigating for corrosion, but I need some advice:
1. If the integrity of the body is good, should I apply something like rhinoliner or just apply a healthy dose of corrosion inhibitor?
2. Should I rhinoline at all?
3. Preserve the exact original or trick her out?
This is my 3rd bronco, started with a 66 and cut her, the 73 was already cut and this is the closest to original that I have seen.
Thanks for your thoughts.
STLKIKN
Calgary Alberta
An un-cut rust free 77 is exceptionally hard to find....
If it were mine, it would remain un-cut.
It would probably get modded with lift, tires, wheels etc,
but like I said, it would be a shame to cut it.
If the body is coming off the frame and being bead or soda blasted, rhino the underside, if not, just corrosion inhibitor.
You can always line the tub and then re install the factory floor coverings (be it rubber or carpet) just to protect the floor from rot.
Broncoholics
Broncoholics
Washington State
I wouldn't cut it either. Its lasted this long, might as well make it look like new since it so close. If you don't like it afterwards sell it for all kinds of cash and get what you want.
snowcat256
20472[/snapback]
Well I see you went thru the trouble of buying her off ebay...dont cut ..leave it all original..theres to many cut broncos running around this place as it is..one cut is one less...undercoat and enjoy...snowcat
figjeti
