That stuff under the hood
AdamDude04
On newer cars, they have this black liner on the underside of the hood. It's a fire retardant/sound blocker.
I was thinking of getting some of this stuff new (thought about a mid 90s Bronco, but no) and install it on the firewall, wheel wells, and under the hood - Mostly to make the truck as quite as can be.
What's that stuff called, and any heat issues I may ecounter with it installed in places other than on the back side of the hood?
yo
Hood insulation.
Try our main sponsor here; JJEFF'S BRONCO GRAVEYARD FOR Insulpad Floor or Firewall Insulation
http://broncograveyard.com/bronco/i-37685-insulpad-floor-or-firewall-insulation.html
4' x 6' single sided sheet.
Insulpad thermal/acoustic insulation is a lightweight, foil faced, blanket type insulation with multiple uses. Insulpad offers excellent thermal and acoustical performance and carries a class-a fire rating!
Made from durable natural fibers, Insulpad contains no fiberglass and does not itch or cause skin irritation. The fibers used to manufacture Insulpad offer excellent sound absorption properties and every fiber used is individually treated with and EPA registered anti-microbial agent that offers excellent protection from mold, mildew, fungi, and pests as well as fire resistance.
Insulpad's pure aluminum barrier reflects unwanted radiant heat and offers excellent protection from air currents, moisture, and vapors.
FEATURES:
- Superior Acoustical Performance (Better than - Foil/Bubble pack products)
- Excellent Thermal Performance
- Helps Heat & Cool More Efficiently
- Easy To Use and Install- Class-A Fire Rating- No Itch or Skin Irritation
- No Formaldehyde or Harmful Irritants
- Durable Natural Fiber Padding
- 99.5% Pure Aluminum Foil Facing
- Patented Manufacturing Process
- Versatile Product With Multiple Uses
- No Protective Clothing Needed
- Under Hoods
- Headliners
- Firewalls
- Floorboards
- Sleeper Compartments
- Complete Interiors
Our Price: $29.00
There are many Brands out there sim to this; Acoustishield
http://www.quietride.com/
ck their WeatherShield door damper & barrier
stops door noise, insulates and protects your upholstery panels from moisture. Now shipping
with all of our pre-cut insulation kits
and consider floor pan inulation as well as cab side of firewall around grommets & over clutch linkage cut-out etc.
