tailgate window switch problem
bronco9844
i'm having the same problem many have had...the tailgate window works when it decides to...mostly it doesn't want to...i replaced the motor and it worked great while at the shop but as soon as i get it home...nada...it sounds like the safety switch is prevent the key from activating but i'm not too sure...the only way i know about the safety switch is from reading about it from ya'lls post...i also read about by-passing the safety switch but cannot find that post again...can someone help
avatar
I can't answer the Q but would like to know the answer too.
firelt90bronco
Ask me about my job
northeast
Byppassing the safety switch isn't hard. Its located in the top corner of the tailgate near the latch. All you have to do is connect the two wires coming from the switch.
wtfdissux
Buffalo, NY
take the two wires goin into the gate (behind the left rear tail light) cut them and splice them directly to the motor wires this will eliminate the tail switch and safety switch down side is that you cant use the key to open but will find out if either are bad if it works after your done then one or both are bad if not then would suggest motor and or regulator also check the ground and if needed run a new one I ran a self tapper into the inside of the light opening with a wire and eye to one of the screws that secure the inner panel did not leave it of course but makes for a good ground when testing
another hing is the bracket that the motor and regulator is attached to look to be sure it is still attached esp. at the bottom if not let us know and I will tell you a real easy fix
Big Country
San Antonio, TX
I don't know if mine works because my door key doesn't fit in it. ???
Maybe previous owner changed it out. I need to get a key made for it. But bypassing the switch is a good idea.
wtfdissux
Buffalo, NY
I have had so many tail gates that I bypass as soon as I hook them up dont really know why I keep the key all I need is one (it works doors and ignition)
Coastersfwb
