Tailgate Linkage
Badco8
Badco8
Floyd,Va
:unsure: :blink: Hopefully you can shed some light on this problem. I am in the process if hooking up my tailgate linkage and prior to having the bottom of my tailgate repaired, the original switch arm was wired to the bottom tension bar.
Now that I am ready to install all of the linkages,I have nowhere to hook the bottom link.
I found a link at the JY but it had been removed from the old tailgate and was lying inside.
Is this piece necessary? From what i have been able to gather, it is supposed to prevent opening the tailgate unless the window is all the way down.
Where do I go from here?
firelt90bronco
Ask me about my job
northeast
Is it the spring loaded rod on the passenger side that loops onto that hook? I never hooked mine up, and the window still works, its just to ease the dropping of the tailgate.
Badco8
Badco8
Floyd,Va
No, that would be the tension bar. This is one of 4 rods on the tailgate latch assembly that opens the tailgate. :)) :)) :-B
The rod that hangs down that has like a rubber covered hook bent in it gets pulled down when the window goes down thei then enables the inside handle to release the catches . Its a safety so you cant try to open the gate with the glass up . It just hangs down and theres a plastic clip that it runs through to keep it centered you will see the hole the clip plugs into on the innner skin of the gate . :D /emoticons/[email protected] 2x" width="20" height="20" />
Badco8
Badco8
Floyd,Va
Thanks,I'll try it tomorrow. [-o< [-o<
firelt90bronco
Ask me about my job
northeast
What are you laughing about, my tailgate WORKS!!!! :)) :))
