T-Case Question
White90Bronco
I have a 90 Full Size Bronco w/ a BW1356 Electronic Shift. Is there anyway I can put a NP205 T-Case in it? Any help would be appreciated.
ocalabronco
ocala, Fl
yea, its easy. just unbolt the 1356 from the tranny and the NP205 should bolt right up. spline counts are the same. you will have to modify the shift linkage to work in the factory slot (underneath the carpet next to the tranny access panel). other than that, you may have to modify your driveshafts because of the width differences
Val
