keeprollling
Hello everyone, it has been a while since I have been online. Right now I am working on getting my truck lifted and ready to run on some desert trails. Attached are some pictures of the work so far. The first few are of breaking down the front end and then you can see the beams all sand blasted and cut up ready for welding. Right now the Bronco has the rotors have been placed back and next the limit straps will be welded and bump stops inside the coils will be added. It is looking good, and the guys at the shop were able to find a used set of 35x12.50x15 pro comp A/T tires and some wheels for 400 bucks so those will be installed to replace the 31x10.50x15 tires that did not match.
I will keep you guys updated and upload more pictures when available.
