stock 9" rear on 79 bronco
fenris
I was wonderin on the stock 9" rear on the 79 bronco if both wheels turn or if its just one?
F
fenris
Do you know if a 1979 bronco Custom with a 9" 3.50 would have LSD?
Foul Al
pennsylvania
you will have to look at the tag on the pass side of the front of the rear axle. the tag should read 3 L 50 xxxx. the L means limited slip. most customs are bare bones bronco's. or you could jack up the ass end and start the rig and see what happens....
Fordified
The Mother Lode of CA up at 5000ft
Just as Al said, as long as your tag is still there it will tell you or jack the rear up and turn one of the tires by hand,They should turn the same way. My 78custom has a LS but it all depends on if the original owner wanted the option.
If you do have a LS more then likely it is going to function as an open diff now anyways from wear.
