hello all,
I have a 1995 bronco that I am slowly working on. When I first bought it a couple of months ago the brake lights would periodically stay on after you used the brakes. They would also come out once you turned off the motor as the pedal would let down a tiny, tiny bit. So I checked the brake fluid in the master cylinder---it was full. Later I replaced the sending switch on the pedal---it didn't seem to change much either.
Since then we have had some cooler weather. Now when I drive it the pedal is sticking at about the midway point. It does not appear I have any links at the wheels as I see no fluid and the master cylinder is slap full.
I'm thinking next step is the master cylinder as I understand they can leak internally causing them to stick. This sound like a plausible next step?
