steering issue
kc3017
Ok so I've read ALL of the posts here...
I now know how to fix my tailgate window & what size tires I can use...
My problem is in the steering. I've replaced all the parts from tie rod to tie rod buit I still have a significant amount of play in the wheel. Everything is tight...
Also, after turning a corner the wheel doesn't return to center. I'm going to remove the stabalizer, as advised in another forum, hopefully that will work...Suggestions?
mbtech2003
cape cod, mass
33531[/snapback]
ok nm my last comment lol sorry :lol:
did u do an alignment after your tie rod replacements??? sounds like u need a little more toe in on your front end to help your steering. let us know :)>-
ocalabronco
ocala, Fl
the toe shouldnt really affect how your steering returns to center. to me, it sounds like your steering box needs adjusting or your rag joint ate it. on a solid axle rig, it would be your camber throwing it off. but i dont think you have a solid axle, so your rag joint is probably shot or your gearbox it out of adjustment. it happens
Val
