Starter Solenoid issues!!
Donvitto90
Detroit
Hey everyone,
I have a 91 EB 5.0 and I’m having issues with the wires that go to the starter solenoid (fender mounted) does anyone know which wires are considered hot wires and what they look like? Or better put which wires would directly connect to the positive battery terminal?
D
Donvitto90
Detroit
So from that link it talks about the power distribution stud... where is that located? Everything power wise for me is on the relay and I think that might be part of my problem...
chrlsful
S. Amherst, MA 01002-1827
Off topic:
(love the link in #2.
I seek the mini starter & 3G alt. to smooth the engine bay (no relay, no solinoid).
Just a different (ford hasa better) idea...
Yo Don,
S = Start (Keyed Red/Light Blue from Ignition Switch)
M = Motor (Cable to the Starter)
B = Battery (Cable from your Battery + Terminal & From Alternator & to Fusible Links
Relay Usual Failures:
Check for continuity between relay mounting bracket and clean inner fender (ground).
Rust, grime, paint etc interferes with relay control circuit.
Relay Ground Wire Addition & Location Video in an 86
Source: by JKossarides ("The Bronco", Jean) REST IN PEACE MY FRIEND ... at https://www.supermotors.net/registry/17406/65739
Relay contacts become welded close so starter runs on or pitted so no cranking.
Here is the 1990 F Series/Bronco Pre-Delivery Shop & Electrical & Vacuum Troubleshooting Manual (EVTM), Partial by member Kingfish999 in Google Drive (similar to your 91) @ 1990 Ford Truck service manuals - Google Drive
Slow scrolling for my slow Comcast Highest Cost Blast Internet..
Suggest you download the docs for faster scrolling and to use the page index.
1991 Bronco Dealer Brochure by Ford via via Dezo's Garage @
https://www.xr793.com/wp-content/uploads/2020/07/1991-Ford-Bronco.pdf
