Speedo Cluster
BIG BAD BRONCO
boston, MA... soon to be RI though
hi everybody... havent been here in a while. i am finally getting my bronco back and have a lot of work to be done. i want to know if anyone has taken out the instrument cluster on a 92-96 bronco? if so how hard is it to do? since the mileage is electronic, if i were to find another cluster to put in will the milage stay the same or will it show the mileage of the vehicle it came out of. i want to put some custom graphics on the guages and also change the green background lighting color. has anyone ever done anything like this? is it possible to do. i found this link sxplaining how to do the graphic... http://www.rangerpowersports.com/tech/inte...stomgauge.shtml ... but i wanted to know how hard it is to take it all apart before i damage something
thanks a lot in advance
jonnyb >:)
gregor
gregor
pope afb north carolina
i have a 90 bronco and i have taken everything( dash and instruments) out and it was just a matter of unbolting everything. as far as the mileage staying the same i am not sure how that would work.
G
Guest_raldo_gtm
Guest
It's relatively easy to disassemble the whole dask. You have to take off the plastic trim and take off the torx screws that hold the trim and also the ones on the gauge cluster. Then pull the cluster out and take off the wires, they snap on and off. You can purchase another cluster, but make sure that you buy the right one. The 92-96 are not all compatiable, the 94-96 have abs and the others do not. Just take off your old speedo and install it into the new one. You can use the US version or Canadian version, just take off your old speedo and reinstall. Oh yeah, you can also take off the automatic shift indicators,if you need to. I bought euro reverse white face gauges for my 94 bronco. I wanted to get a new cluster, one with a tach, but I can't find one....and I got out bidded on ebay too. So, I just bought white face gauges.
88pimpin
Postwhore, Pimpin Ain't Easy
Bozeman, MT
If you want some custom gauge faces, check this post out:
http://broncozone.com/forums/index.php?showtopic=2676
Here are the gauge faces I ordered from him for my Cougar:
Here are his Bronco gauge faces, which I'm not sure if they fit the newer ones, past 91:
1. http://members.tccoa.com/93pimpin/Bronco/FordGauges1.jpg
2.
Sufferedformula
