rotor/hub assembly.
Big Ragu
palm bay fl.
Hi All.....does anybody know where I can get the rotor/hub assembly for a 93 Bronco with 4 wheel ABS at good price ? I just came from ford. they tried to **** me over the coals with a price of close to $300.00!!! for 1 side!! I need help quick, my truck is down now over a week
KJEfting
Ogden, Utah
Whoa buddy. That assembly comes apart. Remove the inner bearing seal and the inner bearing. Flip it upside down and pop your lugs through with a hammer. The heads of the lugs will not clear the "gear looking" ABS ring. The ring is just pressed on. I just used the lugs to pop it off by tapping them on all four sides of the ABS ring. It just pops right off. Then you can seperate the rotor and hub. If it wants to be a bugger, heat it up a little with a torch first. You'll save yourself a lot of money doing it that way. This way you only have to replace the rotors, which you can get at any auto parts store. Hope this helps.
-Ken
Big Ragu
Big Ragu
palm bay fl.
I took them apart and found that the outer race was loose and looked like it might have spun. so when I
to put in a new race I found out the it did spin and new race was just as loose. So not wanting to take a chance I just wanted to replaced everything. Autozone had them online but didnt sell them in the stores nor could get them to the store. "WHATS WITH THAT!!!!??. Well I bought them online orded them mon. they came today. Hub/rotor, wheel studs , races installed and even had the ABS. ring on it. Just got done putting the pass. side on. went on like butter. The best thing is that they only cost $100.00 with shipping
too my door. Kinda hard to beat ........
thanks all for your help
Ragu
Coastersfwb
