Rewiring A 1988 Bronco Ii
Skyler
We're restoring our old Bronco II and are considering rewiring it. We've had a lot of problems, especially in the starter circuitry and some of the dashboard wiring. Does anyone know if there are replacement harnesses available? If not, what is the best way to proceed -- removing each part of the harness and reconstructing it on a bench?
Many thanks for your advice.
Please respond directly to [email protected]
Jim "Skyler" Cullen
billybroncojr
MI
I don't know if they have the specifics you are looking for, but www.rangerstation.com has tons of info on these trucks.
Possible suggestion is to find a donor vehicle and take the wiring off of that, unless you have the time and patience to run wires!
Later,
Jeff
Bronwen
Guest
Hate to be the bearer of bad news son, like I did, you MUST remove everything and even replace from scratch :p /emoticons/[email protected] 2x" width="20" height="20" />
Gary wilder
