I just picked up a 78 Bronco with the rear glass not operational. I have cleaned the contacts on the front switch that did not ohm out properly, replaced the relay that buzzed. I now have switched up and down 12V power to every connector just like the diagram but the window does not operate. The motor goes up and down by applying power directly so I know it is good, I have a bad ground.
I have located the ground coming off the dash switch its good, where does the main harness ground? the diagrams show two grounds, I have not located the other, any ideas of the location?. I may have issues with my ignition switch as well, I can wiggle the key and make the window relay buzz, is it possible that they share a ground?
