Rear Brake line Gear oil what does it all mean/
MDDYATV
Fallon, Nevada
So I went out to the bronco today during lunch and found a puddle of gear oil under the rear axle under further investigation I found that it a flexible line that attached to the rear axle at the same place as the flexible brake line that connects to the hard lines. I am not sure what this is it seems to be a vent line but it goes up by the gass tank. it looks like an easy fix. can anyone tell me for sure what it is I had a LMC catalog in the bronco but could not find that part. so can I just square off the end and rezip tie it or what?
Roadkill
Killeen, TX
You are exactly right, it's the vent for the axle. Just square up the end and zip tie it back on.
M
MDDYATV
Fallon, Nevada
Thanks now I guess I need to change the oil in the rear end I dont know how long I have been leaking it or how much is in there.
bigtrux
Murrieta,CA
Just find out what fluid you need and take the fill plug out and fill it till it is at the bottom of the fill hole ? unless you want to replace differanital cover seal ..... good luck ...
Coastersfwb
