Rear Axle knowledge
Auggie
Saint Augustine, FL
I need to find out what type of rear axle I have.  I guess I do not "need" to know as much as want to know for future problems.Is there any way for me to identify what I have.....part numbers?, dimensions?, stock for a '77?
Thanks
 Your info. shows  "Axle is B8J" What ever that means..??
'76-'77  "stock"  axles are called out as;  "big bearing"  with 11" x 2-1/4" brake drum.
              There's a driver & pass. side axle due to length.
Great info. there Fyreduck..!!  Thanks for that.
I like to remind folks that, due to one, & sometimes more "previous owners" ..., there's a chance
the axles have been altered/up-graded.  31 spline differential & axle shafts for one example.
Or, gear ratio changes for another.
However, these are easy to test for & should be done B/4 ordering any parts.
Sometimes the whole axle has been swapped out.  (front and/or rear)
(possibly fr. a different year) Not a bad thing.., just needs to be known & noted.
This holds true for other drive-train/steering components as well.
Yo,Auggie,
I made a mistake 15 years ago by telling someone to use the Driver's side label to ID their Rear Differential (axle, pumpkin type, etc.); turned out that a previous owner had swapped a Dana 60 in place of the stock 9 inch
so... a run down of it and front Dana 44 by Kenneth C at http://www.badshoeproductions.com/rear.html
Ford typically builds 4WD trucks with a slightly faster/numerically lower front gear ratio than the rear so that off-road steering is enhanced. So a truck built with 3.55 rear gears will have 3.54 front; 3.08 rear - 3.07 front; 4.11 rear - 4.10 front, etc..." Following was in my MS WORD Notes and the source, Randy's Ring & Pinion has removed it from their current web site; The gear ratio in the front of a four wheel drive has to be different from the front so the front wheels will pull more. There have been many different ratio combinations used in four-wheel drive vehicles, but not so that the front will pull more. Gear manufactures use different ratios for many different reasons. Some of those reasons are: strength, gear life, noise (or lack of it), geometric constraints, or simply because of the tooling they have available. I have seen Ford use a 3.50 ratio in the rear with a 3.54 in the front, or a 4.11 in the rear with a 4.09 in the front. As long as the front and rear ratios are within 1%, the vehicle works just fine on the road, and can even be as different as 2% for off-road use with no side effects. point difference in ratio is equal to 1%. To find the percentage difference in ratios it is necessary to divide, not subtract. In order to find the difference, divide one ratio by the other and look at the numbers to the right of the decimal point to see how far they vary from 1.00. For example: 3.54 ÷ 3.50 = 1.01, or 1%, not 4% different. And likewise 4.11 ÷ 4.09 = 1.005, or only a 1/2% difference. These differences are about the same as a 1/3" variation in front to rear tire height, which probably happens more often than we realize. A difference in the ratio will damage the transfer case. Any extreme difference in front and rear ratios or front and rear tire height will put undue force on the drive train. However, any difference will put strain on all parts of the drivetrain. The forces generated from the difference have to travel through the axle assemblies and the driveshafts to get to the transfer case. These excessive forces can just as easily break a front u-joint or rear spider gear as well as parts in the transfer case.
Auggie
Auggie
Saint Augustine, FL
Thanks for all the info.....sorry it took me so long to get this out to everyone.........really appreciate the info.
fred tyler
