ratcheting noise in 4wd
Tim B
Pittsburgh PA
Hey all I recently bought a 1990 bronco 2 4x4 5 speed manual hubs. When I put it in 4wd it makes a constant ratcheting/clicking sound. I replaced the hubs and its still doing it. Any idea what it might be? Thanks.
You Tim,
Are you hearing that noise when driving on paved roads, or concrete surfaces?
Are all 4 tires the same size, inflated to same pressure and worn same amount?
FSB
Tire Diameter/Circumference & Air Pressure Differences; "...You will recall that at the beginning of this section, we mentioned that we had made sure that all four tires on our truck were the same size, were worn the same amount, were inflated to the specified pressure and were subjected to reasonable loading. Avoiding driveline windup was the reason for this. Figure 18A shows that tires of even slightly different size roll different distances every revolution. Figure 18B shows that the same effect is true for tires that are the same size but inflated or loaded differently. Operating a 4 x 4 in 4WD with tires of different size or inflation will produce driveline windup, even when driving straight ahead! If the vehicle is being driven in 4WD on dry, hard pavement, the driver will notice drag and may experience the hop, skip, bounce effect as the front or rear wheels release the windup..." in Four Wheel Drive (4X4) General Information, Operation & Troubleshooting TSB 92-1-8 for Bronco II, Bronco, F Series & Ranger (COMPLETE); Includes Electric Shift On The Fly (ESOF) Troubleshooting & Hub Operation
Source: by Ford via
http://api.viglink.com/api/click?format=go&jsonp=vglnk_145711080512810&key=6ed47b392b9edfe394b9e89b72717104&libId=ildxzrow01000bgv000MAd5v9l49q&loc=http%3A%2F%2Fwww.fullsizebronco.com%2Fforum%2F7-1980-96-bronco-tech%2F274770-wont-go-into-4x4.html&v=1&title=Little%20help%20please%20-%20Ford%20Bronco%20Forum&txt=http%3A%2F%2Fapi.viglink.com%2Fapi%2Fclick%3Ffor...f%253Fid%253D35193&out=http%3A%2F%2Fwww.revbase.com%2FBBBMOTOR%2FTSb%2FDownloadPdf%3Fid%3D35193
danno
